Not a bug
Distribute vertical - MD4 7 with 3.15 - bottom object doesn't distribute evenly
Zach 9 years ago
in IQANdesign
7
I will see an even spacing between all except the last object when using the vertical distribute button.
Using an MD4 in 3.15, did not see a patch note that this was fixed or a post.
Hope it is not redundant to mention.
I am not sure that I understand what the error is?
I made a quick test with four text labels, the top one at 100 pixels from top, and the bottom one at 400 pixels from the top.
Before pressing Distribute controls vertically:
Just after pressing Distribute controls vertically:
The Distribute controls vertically has moved the middle objects, they are now at 200 and 300 pixels from the top.
Only the middle objects are highlighted after the operation, these are the ones that are moved.
Which version is that in?
So if the remainder is higher, if you have more objects to space, then the remainder will be consumed on the last two objects I believe, and instead I would like the last object to come up instead of have my spacing offset between two objects in the set.
