Adjust item will not increase above 99999.99
J C. Crow 5 years ago in IQANdesign updated by Gustav Widén (System support) 5 years ago 2
I have a memory channel with a range of 0 to 9,999,999. I have it in an adjust group with a step size of 1608. (The channel is meters and 1608 is 1 mile.) When using the adjust tool in runtime, the tool will not allow the value to increase above 99999.99.
Satisfaction mark by J C. Crow 5 years ago
I checked and the clamping at 99999.99 seems to be with the MD4 adjust menu.
When the value is changed with IQANrun, the MD3 or application logic, it is possible to increase further (up to the limit set on the adjust item).
Fixed in 6.00, see release notes
http://divapps.parker.com/divapps/iqan/Downloads/IQANdesign%206/ReleaseNotes6.00.48.htm
47996MD4 adjust menu: parameter adjust limited to 99999.99
IP can now be adjusted up to 2 000 000 000.
FP can be adjusted up to 20 000 000.
