Measure CAN bus Critical Error on channel
Pawel Pekala 5 years ago in IQANdesign updated by Gustav Widén (System support) 5 years ago 3
Is there any way of intercepting "CAN BUS Critical Error" using IDC logic for diagnostics purposes? When CAN bus goes into that state is causes all expansion module and /r J1939 modules to go into "no contact" mode but I was wondering if there is a way for IDC to sense critical bus error.
Cheers
The status can be seen in the system layout, but there is no function to pick up this status in a channel.
Should I change the question to a feature request?
Me sad :o(. I think this could be helpful feature to have.
Changed topic from question to feature idea.
