Is there a way to keep the switch button static to false when a certain condition is met?
J Kelly 5 years ago in IQANdesign updated by Gustav Widén (System support) 5 years ago 1
I am trying to keep a button disabled even when a user touches the screen to try to enable. Is this possible in IQAN?
Have you tried the button enable property?
When enabled is false, the button will be grayed out.
If you have it connected to a toggling VDIN, you'll also need to reset the VDIN when the enable is false.
