MOTOR POWER CONDITION
Dan Samuels 5 years ago in IQANscript updated by Gustav Widén (System support) 5 years ago 3
I work for a municipality, we have a JD tractor with an alamo 30' mower. Controlled by IQAN MDM. The display reads "MOTOR POWER CONDITION" we have changed all the filters in the system. Does anyone have insight as to the possible problem.
Thank you, Dan. (mechanic@lakestation-in.gov)
Answer
Answer
Hi Dan,
Each OEM configures their IQAN systems to meet the needs of the machine.  The message on the display would be something Alamo set up, so you would need to check with them or possibly in a user manual to see what would trigger the message.  It is not a message that is generated by an IQAN system by default.
Answer
Hi Dan,
Thank you, I will check into it
