Change status of analogue voltage inputs when simulating
Kevin 9 years ago in IQANsimulate updated by Gustav Widén (System support) 9 years ago 4
What would be really useful would be setting the status of a analogue input to a given value. This value needs to fall outside of the max and min values as configured, ie. a disconnect or overvoltage. We need the ability to simulate a transducer disconnect to see how the system reacts, but it dosn't look like its possible, only on outputs.
Try this button in the simulator:
Great, thanks for the info.
To get an even better view of the error range, you can also put the VIN in a simulation group.
Now when switching to the raw value range that Arno shown, you also see the raw value, e.g. 198mV. In IQANdesign you will see the corresponding sclaed value (e.g. % for the joystick)
