Save measure from multimeter
C. Drouaud 5 years ago in IQANrun updated by Gustav Widén (System support) 5 years ago 2
I have a bug/error every time I want to save measure from the multimeter (custom group of measure). IQANrun crash and I can't save my measure.
Can you please check this out ?
Thanks in advance
I checked and found a crash report from another user that sounds as if it could be the same issue.
When you get the crash, do you get a dialog box with a button for send bug report?
If so, could you press that button to submit it? This will contain some info that might help us find out what the problem is.
