IQANdesign 6.00 - Undo not returning channel to original position
Pierre Fagrell 5 years ago in IQANdesign updated by Gustav Widén (System support) 4 years ago 6
I have a channel "Production running" that I want to move inside the function. Originally it is here:
Image 1688
I move it down a few centimeters to this position:
Image 1689
Afterwards I realize this was a mistake so I hit CTRL+Z to undo. Instead of moving back to the original position the channel is moved to a new position like this:
Image 1690
Even if I try many times and move to different positions this item will always end up here after an undo. I have saved a copy of the project if you want to look at the project file.
Check if you are in 100% zoom level. I got the same issue if zoom level is other then 100%. But there is no reset to 100% or visible info about current zoom level.
The exact same issue happens regardless if I have 80% or 100% zoom level.
Ah!
I was able to reproduce the issue, it happens in both 5.04 and 6.00. Thanks for sharing the printscreen that shows the problem.
It happens when you move the "shadow" of a public scope channel. With the undo operation, the shadow takes the position of the public scope channel it originates from.
Fixed in 5.05, soon available in 6.01 as well.
