C++ convert to IQAN
Kerim 9 years ago
in IQANdesign
5
Hello ,
We would like to convert from C++ to IQAN design.
I can very easily convert from if else to IQAN function.
But I dont convert from while to IQAN function.
So we can create while function then it s fake.
Now How can we do "while" or "for" in the IQAN design?
for a while function you can use a SMC-channel, you'll find it under the miscellaneous-tab.
In the SMC-channel you define the diffenrent condititions (while x=0...)
Each calculation channel (IDC, MAC, DMAC,..), and also many other functions have a property called "Functions selector".
If you select your SMC-channel, the calculation channel gets more states.
In your solution library should be an example for this: "Closed loop control and manual state.ida3"
Each enabled channel and object in the application will be calculated exactly once, each system cycle.
For me, the great benefit of this is that I will know that the application will always complete the calculation on-time, every cycle. A simple mistake in application logic cannot cause it to become stuck in a loop inside the application.
