Is it possible to copy/transfer adjust items and adjust groups from one project to another?
Dennis Parkes 4 years ago in IQANdesign updated by Gustav Widén (System support) 4 years ago 1
If you mark a function group and chose File-Export - Export components, you get a file containing that function group along with measure groups, adjust items and adjust groups that were connected in the original application.
You can then select File -Import to add this to your new project file.
Note that even though these channels and adjust item appear the same, they are copies.
If you were to take this new project file and send it to a master with the old project file, the settings are cleared and replaced by application defaults. Since both the Project ID and the individual component ID:s differ.
