Low frequency PWM
Ed Schippers 8 years ago in IQANdesign updated by Ulrik Zakariasson (Software development) 8 years ago 3
Hi
To control a visco fan clutch a low frequency PWN signal is needed ideal 1 to 5 Hz
a standard Iqan PWM goes only as low as 10 Hz.
is it a problem to use a Dout and plus this output? using a timer and change the on period?
Answer
Answer
I used a standard Dout, but the principle you are describing.
worked fine..!
Satisfaction mark by Ed Schippers 8 years ago
