How can print the Logs to files?
Phan Hiep 7 years ago in IQANdesign updated by Gustav Widén (System support) 2 years ago 6
Hi everyone. I have 1 project with MD4-7. I create 1 Logs channel in Diagnostics. Now I want to print it to a files (.txt, .pdf...) and get this file like database. Anybody can help me to solve this issue?
Thank you so much !
Image 541
Answer
Answer
Hello Phan.
You can use IQANrun to download and save the logs as a excel file.
Use IQANrun to connect to the MD4.
Then go to the 'Logs' in the toolbox section.
Double click on the log you want to enter in to it.
Then you use the 'Save' function under 'File' in the top right corner of IQANrun.
Here you can select the file type you want to save the log as.
Answer
Hello Phan.
Thank you Thomas, i will try this way.
Is there a way to use IQANscript to do the above as part of the script? We are using IQANrun in a number of applications to save log items to an excel file and would like to do automatically.
Yes, the "Get log" action in IQANscript lets you select which file formats you want each log to be saved as.
