IQAN 2.6 switching pages automatically
Zach 9 years ago in IQANdesign updated by Gustav Widén (System support) 9 years ago 3
I tried to save space in a program by deleting a display page function group that ran the pages from a state channel and virtual inputs.
Then I put the page selection onto the buttons in the display pages of an md3 running 2.6
So now when I press the down arrow key, the next page displays.
How do I set a trigger for a specific page to appear?
Satisfaction mark by Zach 9 years ago
I am not sure that I understood which method you used, but there are basically two ways for bringing up a display page.
The method I use the most is that I set an action on a button, where the action is to go to the page you want to navigate to. Like this:
The other method is to use the Show property on the display page. That way you can control the showing of the page from you application. The last display page to see a change from false to true on its "Show" property will be displayed.
Thanks, worked great
