Declined
MD3-Adjust Group-Reference Channel-Will only display to one dec place on the MD3 screen.
Nick Pridham 9 years ago in IQANdesign updated by Ulrik Zakariasson (Software development) 8 years ago 3
I would like the decimal place count for the reference channel to automatically match that of the parameter being adjusted.
The IQAN run view is fine.
In the MD3 menu system, the Reference channel is shown with three significant digits. So if your value is <10, it will show two decimal places.
IQANrun is always showing two decimal places.
If what you are adjusting is a VIN, then Actual value (the value you are adjusting) and the Reference channel use the same method, both show three significant digits (or more for values >999)
It is slightly different for the FP channel, For the function parameter, the Actual value is always shown with two decimal places.
The problem I ran into was needing to see 4 significant digits in the reference channel.
Request: Can we have a property to specify the number of significant digits to be displayed when configuring a reference channel ?
