system information
Ed Schippers 7 years ago in IQANdesign updated by Ulrik Zakariasson (Software development) 7 years ago 2
Is there a way to see in the application if a adjust group is unlocked?
I want to show some extra stuf on the screen when a particular adjust group is unlocked.
If it is not possible it would be a nice feature for in the system information channel.
regards, Ed
Answer
Answer
Hello Ed.
What you can do is to add a PIN code channel in the application.
On adjust groups you can select PIN code channels instead of typing in a PIN code.
The when you enter the correct code for the group the channel in the application will go from false to true.
Satisfaction mark by Ed Schippers 7 years ago
Answer
Hello Ed.
