MC31 I/O strange behaviour
Frederick Prigge 9 years ago
in Master modules / MC3
updated by Gustav Widén (System support) 9 years ago •
5
I have a MC31 setup than is behaving unexpectedly. Some I/Os seem wrongly mapped in the software. When I toggle Dout J, the pin C1:17 does not change state, but outputs F-G-H-I seem to work normaly.
Also, reference A (on pins pins C2:1 and C2:2) is not providing 5V (in fact, I see 0V between those pins). Any analog sensor connected to this ref is obviously not working.
This is using SW 3.16.8.3850.
Please advise.
Please advise.
What do you have connected on DOUT-J?
For the problem with the VREF, does that error continue to shwo if you disconnect connector C2? Most cases of VREF errors are due to the VREF being overloaded or shorted.
What made me think of an I/O mapping error is that with SW w/3.15 on the MC31, inputs were all wrong. When I physically toggled some pins, the effect was shown on other pins in the software!
As far as overloading the vrefs, woulded the display pop-up some sort of a dialog box?
Thanks again for your great help and fantastic product!
Yes, a VREF error on the MC31 should show up as a popup on the IQAN-MDx, if you have a master display in the system and they are connected on the Diagnostics bus. You should also be able to see this error if measuring in IQANrun or IQANdesign.
I am measuring and programming via the Ethernet port of an MD4-7. BTW, the "gateway" function to program all masters on the system is great!
So as for the VREF error, no, I do not see a message on the MD4. Would it show even if the error is present at boot time? Is the MC31 broadcasting this error to the displays constantly or could it have been "missed" because the display boot time is longer?
For the problem with the VREF on the MC3 not showing on the MD4, the VREF error may not have been seen as a popup on the MD4 if it was present at boot-up, if you were using 3.15 or earlier. This was solved in IQANdesign version 3.16
http://divapps.parker.com/divapps/iqan/Downloads/IQANdesign%203/ReleaseNotes3.16.8.htm
24023 MD4 do not show errors from other master modules on startup
Could happen if another master module sends out error messages before the MD4 GUI is up and running. Fixed.
For the isseue with the MC31 block diagram mapping, it would have made sense if you downloaded, then rearranged the block diagram and started measuring without sending. This because measuring works based on channel ID:s, and they don't change when rearranging. But it sounds as if this was not the case here.
When you had the issue on version 3.15, I assume this was not a beta but the relesed version 3.15.16?
Glad you like the MD4 routing function!
