Button action control does not allow access to all logs
J.C. Crow 7 months ago in IQANdesign 0
I am working with a multi-master system in IQAN 6.02.7.5650. When selecting the action for a text button, only the logs in the MD4 are available. I would like to be able to use the button to bring up logs that are on the other master modules such as an MC43.
It would also be nice if VDIN could be used in non-display masters. As it is, when you need a VDIN, you have to send it from the display to the MC43 using a CAN message.
