Digital Output warning
Stacy Turner 6 years ago in IQANdesign updated by Ulrik Zakariasson (Software development) 6 years ago 2
I have a digital output(A). It is shaded yellow all the time and has a warning: 'Properties Not Available'. If I add another output(B) I don't get that warning. The output does work correctly. Any ideas where the warning is coming from.
Thanks
You get more details on the warning in the project check dialog. It will tell you that a certain property is not available no the assigned module. The project check dialog also indicates which property that has the warning.
For a DOUT channel there are properties soft start/stop time and peak and hold. These properties are only compatible with XA2 and XS2 modules. If the DOUT is assigned to any other module this warning will appear. The property value should then be set to Not used or the default value to get rid of the warning.
