TSC1 setting Torque Limit
Antero Salojarvi 5 years ago
in IQANdesign
updated by Gustav Widén (System support) 2 years ago •
2
How can i set TSC1 torque limit to 100% when using speed control?
Engine spec for TSC1:
The built-in TSC1 channel for speed control sets the torque to 0xFF.
I see you are using the Kohler engine, they have a special requirement to set torque to 100 when using speed control.
To implement this in IQAN, you can build up the TSC1 message using JPOUT and JFOUT.
See attached example:
TSC1 speed request kohler.ids4
From 6.08, this can also be done with the built-in TSC1 channel, with a separate channel for torque.
