QCode Type Mismatch with External Function
Joe 5 years ago in IQANdesign updated by Gustav Widén (System support) 3 years ago 3
Can anyone explain why this is happening? It appears to be random as I can sometimes get the error to go away by changing something unrelated in the external function and saving it.
Error in Program:
Image 1795
No Error in External Function:
Image 1796
Deleting the External Function reference to convert them to standard function groups causes the errors to go away.
One way to get a value type mismatch is if you change the value type of one of your FGI:s after writing the Qcode.
But in the example here, the value types match. Also, such a value type mismatch would be detected by the project check already when editing the external function.
In this case, I am guessing that the mismatch might have occurred in the instance of the external function, after editing the external function the instance somehow hasn't updated as it should.
I believe that if you were to add another instance of the external function, that wouldn't have the error.
Investigating.
This was fixed in 6.01, ref release notes case 49393.
