IQANgo Adjusting Minimum Current
Jason H 3 years ago in IQANgo updated by Gustav Widén (System support) 7 months ago 5
When using IQANgo 6.05.29 to adjust minimum current for a current output, the actual output is not limited to the minimum current value like it is when adjusting using using IQANRun on a laptop.  This makes it difficult to set minimum current values using the app.  Is this by design?  Can the app get updated to reflect how IQANRun works?
We will update the IQANgo user interface for COUT adjust so the min current can be locked when adjusting, just like the MD4 and IQANrun.
Excellent!  Thank you very much for addressing this issue.  It'll make the app much more useful in our applications.
Gustav, has there been any development on this?  Hopefully a fix can be implemented soon.
IQANgo 7.00 limits output to min current when adjusting min, same as when adjusting from IQANrun or MD4.
