Time Values
Zach Dockter 8 years ago in IQANdesign updated by chuck streb 1 month ago 2
Is there a way to break up the time elements in the SIC?
For example, I need to send another J1939 module the value of the minutes, but not the hour or the seconds.
Thanks Ulrik!
Satisfaction mark by Zach Dockter 8 years ago
There is an example of this in the Solution Library, in the project file J1939 set time.ids4
(you can find it here: My Documents\IQAN Files\Solution Library\J1939 set time.ids4)
