Custom variable on X axis in measure group plot (IQANrun and IQANdesign)
Sometimes it is useful to plot variables as functions of other variables rather than time, e.g. cylinder velocity as function of joystick signal.
The feature exists for IQANdesign, the property X-axis item on measure groups.
To use this method of measuring, you need to use IQANdesign for measuring, and also for viewing the saved measurement if you want to look at it afterwards.
The same measure group used in IQANrun will always show time. So you could make a measurement in IQANdesign and use IQANdesign for the X-axis view, and still have IQANrun to see time on that very same .irmx measurement file.
Very nice, then I can do all I need (should have looked closer in iqan design.. :))
Thanks for the swift response!
