MD3 Adjust groups
Hello
Is a first time I have this problem wich the MD3 .
When I want adjust my parameter since the MD3, is not possible.
In my programme, I Have créated the adjust groups ("Réglages")
with a PIN code
When I look the MD3, I have a green clamping for indicate to the user that there is a PIN code.
with the Up and Down button , i select my adjust group and i push on the ok button and i write my PIN code.
After, I Want select the Function parameter but it's not possible. I am blocked and I have another green clamping.
Its possible to tell me why my Fonction parameter is boqued ?
For information, I have a 4.03.27 Iqan Version
Thank you for you help.
Beast regard
Answer
One reason: Are the parameters in a function group, which is disabled?
I found a solution
When you control the activation of the Fonction group, when the fonction group is disabled, all fonction parameter inside, is locked.
Thank you .
