Ethernet Problem - IQD 4.07.15.4769
Nick Pridham 9 years ago • updated by Gustav Widén (System support) 9 years ago • 1
Application file with 1 x MD4 7 and 1 x MD4 10
Ethernet application file download gets stuck after "application file deleted"
Tried from 2 different computers.
Changed cables etc.
Temporary work around is CAN which works fine.
Image 964
Image 965
Do you know what versions you had in the modules before the update attempt that got stuck?
Moth MD4-7 and MD4-10 are currently shipped out with 4.07, but if you have an older one loaded with 3.19 the multi-master routing update could fail.
