Network settings to allow MC43 to connect
C. Harp 9 years ago • updated by Ulrik Zakariasson (Software development) 9 years ago • 2
I need to know which ports I need to open on my firewall to allow an IQAN module to connect.
Thank you for the help.
Satisfaction mark by C. Harp 9 years ago
It depends on what kind of connection you mean.
You can connect to the MC43 module directly from a PC. The ports that are used in this case are described here: http://forum.iqan.se/forums/1-software/topics/419-ports-and-protocols-required-via-ethernet-connection/
The MC43 can also connect to the IQANconnect server and be available for remote diagnostics. In this case the MC43 uses TCP port 60100 (out-going only) to connect to the server.
