Fine adjustment of adjust item function parameter MD3
Barnhart Crane 9 years ago • updated by Gustav Widén (System support) 9 years ago • 3
Is there a way to adjust the tenths and hundredths place of function parameter adjust item using the MD3? It seems only a whole number adjustment is allowed.
For example, How would a user input 7.6 instead of 7.00?
I've looked in the forum and in the manual and cannot find and answer.
Image 1003
You can change the step size in IQANdesign.
If you go to the adjust item or in the adjust group and select your parameter you should have the step size in the property
Wow thank you so much Thomas. I'm not sure how I couldn't find that.
