SAE-J1939 via RJ45 connector
Damian Trutkowski 9 years ago • 0
I need some advice regarding physical connection of SAE-J1939 between 2 modules fitted on separate machines.
Are there any arguments against to connect it by using RJ45 connectors?
I would like to use a HARTING modular connector with RJ45 insert but I'm not sure if it is a good idea.
Image 1112
Image 1113
