Pin Code Value Visible in a PCC
mgoutier 9 years ago • updated by Gustav Widén (System support) 8 years ago • 1
Anyone know if there is a way to make a pin code value visible on an MD4 using a standard PCC and not using a channel to send the value into the PCC?
When the PIN code is entered directly in the PCC channel, there is no way to view it in the IQAN-MD4 or IQANrun.
In IQANdesign, you can view the application default, but not see what value the PIN has been adjusted to.
The only way to view the PIN code is if you control it via a channel, e.g. a TP.
If you do, I'd recommend using full&limited access passwords on the file and place the channel in an adjust group protected by a user level.
On a related topic, also see discussion on reset of PCC here:
https://forum.iqan.se/communities/1/topics/507-pcc-pin-channel-not-be-able-to-reset
