Not reproducible
IQAN Sync 5.02.6 is not able to open files
Antti K 9 years ago • updated by Gustav Widén (System support) 5 years ago • 3
I'm not able to load files using IQAN Sync for Android. It gives error message something like "  No argument for format fmx:iqansync:=uri =connect// ". Same software has been loaded successfully to device with IQAN design and ethernet cable.
Update: It's seems that problem occurs when opening file from google drive. If file is saved to device memory then opening and send to machine is working fine. When this situation appears IQANSync have to be kill. (Never ending error loop with OK.)
Not reproducible
Not reproducible in IQANgo.
