array value use as Value Control on display
mgoutier 8 years ago • updated by Greg Wood 2 years ago • 3
It would be helpful if i could use a specific array channel value as a value displayed in a display page.
IE: Arrayname[0] would be the input channel
The array channel itself do not have a value.
If you want to display any of the stored values from inside the array you need to use a math channel to extract the value and then display the math channel on the display.
To get a math channel to have a value from an array you do like this.
Result:=Array name[ array index]
If you want do be able to change the index you can have a adjustable parameter and use that instead of a fixed number, or use any other channel with a integer value type.
This is what I am saying, it would be helpful to not create redundant math channels just to display a value, it would be nice to just display the array channel value I want.
However, if that array is an array of text strings, can a math channel extract that single string of text?  Is there a method that can?
