High DPI awareness (Universal Windows Platform)
techsupport@posi-plus com 8 years ago • updated by Gustav Widén (System support) 6 years ago • 3
Would it be possible for the IQAN patform software to be made high DPI aware by the Universal Windows Platform compatibility? At the moment, IQANdesign, IQANrun etc. scale incorrectly on multiple monitors setup.
https://docs.microsoft.com/en-us/windows/desktop/hidpi/high-dpi-desktop-application-development-on-windows
There has been a lot of work put into making all our software high DPI aware, especially in version 5. There are still some minor issues when using very high DPI settings that we are addressing in upcoming releases.
You mention multi-monitor setup, is there some specific problem you are experiencing? Are they on different DPI settings?
Yes, different DPI settings. Example: Surface book 2 13.5". Main monitor is 3000x2000 (scale and layout at 200%, anything lower makes text too small), secondary monitor is 1920x1080 (scale and layout at 100%).  If IQANdesign 5.03.14.5040 is running on secondary monitor, some element are not scaled correctly like the right click menu or picklist from the properties. See following.
DPI awareness improved in 6.00 and 5.05
