update 2.60 clones to 2.63?
Forrest 8 years ago • updated by Gustav Widén (System support) 8 years ago • 2
I have to suport old products that were originally programmed with V. 2.60. needless to say When an MD3 needs to be replaced, this causes me a problem.
Is there a way to bring a clone up to date? I do not have an old MD3 laying around any longer.
If you open the clone file in IQANdesign and save the file it will be updated to the version of design that you used to saved it.
The save will be as a application file, not a clone file.
If you want it back to an clone file you need to download the application file to a module and then get the clone from that module.
