+26
IQANrun - Bluetooth connectivity
Raimund Pelz 8 years ago
in IQANrun
updated by Gustav Widén (System support) 2 years ago •
6
• 1 duplicate
Please add the possibility of Bluetooth connectivtiy to IQAN Run for maintance purpose between Laptop and IQAN controller via G11 Bluetooth adapter.
Duplicates
1
Great idea. When is it planned for ?
Thanks
Do you have an idea of when this feature will be implemented ?
Thanks in advance,
We have planned to implement this, but bumped into some issues with device pairing in Windows.
Also see:
https://forum.iqan.se/communities/1/topics/505-iqanrun-bluetooth-connectivity
Hello! Any update on this? This would be great...even if compatibility is reduced to a short list of commercial external USB bluetooth adaptors, in case this results on an easier implementation. Would be better than nothing. Thanks!
Implemented in IQANrun and IQANdesign 6.08
Note that the driver on the PC for the Bluetooth chipset should be up to date to have a robust connection. Some older chipsets on PC:s can have problems.
