CM0504 Software
Greg R 7 years ago updated 7 years ago 2
I am looking into using the CM0504 High Current Controller Module. The Users guide says that there is a diagnostic tool that is used to configure it. Where can I find that software?
Please check back with this link.
https://ph.parker.com/us/17616/en/high-current-slave-controller-cm0504
There was a problem with the file that was hosted there and it is in process of bring updated.  Also, if you are interested, i have also created an external function file that works with the CM0504 in IQAN 5 or later.
CM0504 External Functions.idex
The link still does not have the CM0504 Diagnostic Tool software. I need this software to configure our system.
Also the user manual mentions a Data Link Adapter and drivers. Can the system not be configured through CANBus? Do I need to purchase the DLA through Parker?
