Dual dial on MD3
Frederick Duyvejonck 11 years ago updated by Gustav Widén (System support) 11 years ago 1
Would it be possible to have a dual dial (different colors) on one Image Gauge control showing both levels from two circuits?
One trick you could use on an MD4 is to take the Gauge control, make the scale color transparent and place on top of the image gauge.
See attached example:
Gauge overlapping image gauge.ids3
When I tried this, the tricky part was to get the needle anchors to align in a good way. If that is an issues, one way to solve it is to make the top needle anchor larger.
