high-speed expansion bus
mgoutier 6 years ago • updated by Gustav Widén (System support) 6 years ago • 1
I have a program where I am using an MC43FS, XC43, and an MD4. The MD4 doesn't have any real logic on it, I am using it just as a display. I was hoping to hook up 1 sensor to the MD4 using a high speed bus to capture data at a much faster rate. Any thoughts?
If it is MD4 then I think you will be limited to the MD4 cycle time which is min 10ms. MC43 will run much faster - 1ms. what sort of frequency are you looking to capture ?
