IQAN Develop
Argy 5 years ago • updated by Matt 1 year ago • 4
I am trying to connect to a TOC-8 and I am getting a no response error from IQAN Develop.
The Green LED is on. There are no Orange/Red LED's on.
I am using a Prolific USB-to-Serial port communication cable.
All connections seem right.
My Com-port info is pasted below.
Not sure what I am doing wrong.
Could it be the com speed?
Image 2784
It was a long time ago - but I believe the prolific adapters had problems and I switched to an FTDI chip set adapter and it fixed most problems.  If you can't find a resolution - I would try to find one.
And make sure you download and install the FTDI drivers before you plug it in - windows did not do a good job in finding the drivers (at the time anyway).
Helo, have you managed to solve the connection problem? because i have the same problem and no way works.. Thanks
I was just able to use a sabrent prolific based usb to serial cable (PN: CB-9PTF) to download to a TOC 8 just fine. Just make sure to download and install the drivers from the sabrent website before you plug the cable in to your computer.
