bluetooth iqanrun 6.08.28
chuck streb 4 years ago • updated 4 years ago • 2
I am able to get on Bluetooth with iqanrun.
I am able to pull the code off and upload the code
I did this all without a password. how do i enable a password as this will be going to market ?
There are a couple of different passwords you can set on your IQAN project file.
A good start that I think everyone should have on deployed machines is the Full access and Limited access on the project file.
Image 3640
You may also want to consider adding security levels for IQANrun/IQANgo users.
In the IQANdesign user manual, there is a chapter on Security that takes you through the different ways you can protect your application.
Note that these passwords are used regardless of the interface you connect with.
With the IQAN-G12, you also have some Bluetooth specific properties, for example for controlling pairing with new devices.
Thank you for the information :)
