Pop Up Error Message Discrepancy Between MD4 and MC43
Joe Logger 3 years ago • updated by Gustav Widén (System support) 2 years ago • 2
I use IQAN 6 with this display and module. The error pop up message on the MD4 display does not relay the correct MC43 pin. If there is an open load on MC43 pin C2:46, the display shows open load on pin C2:65. The display gets the output name, error, and module name correct, but the pin location is wrong in the pop up.
Image 4178
Image 4179
Thanks,
What software version is the system running on?
The symptom looks like a problem that was fixed in IQANdesign 6.03:
50457MC4x/XC4x for DOUT-LS, wrong pin numbers in message
Fixed.
