MC43 with MD5 error while "receiving baseline"
Mats 2 years ago • updated by Gustav Widén (System support) 2 years ago • 2
While uploading the IQAN Design program to the MC43 which is connected to the MD5 via CAN the screen goes dark after the "receiving baseline" reaches +-15%. To get this far the module needs about 15 minutes as well which seems to long. Is there any logical explanation for this behavior? ps. the system worked fine in the testlayout, now installed in the machine the module was powered off while uploading (Due to a blown fuse). Since this moment the MD5 does not update anymore.
It should load the project faster via a direct Ethernet connection as the MD5 operating system is very large if it requires updating.
As you were seeing "receiving baseline" that tells me you were also updating version in the MD5.
There are MD5 updates in all of the 7.02 releases of IQANdesign. Do you know which of the versions 7.02.20, 7.02.31 or 7.02.33 you had in the system and which one you were updating to?
You'll probably need to cycle the power and start over with the update. Preferably updating via Ethernet to speed things up.
