Using a PWM out with an MR above 100% on an XC43
John Ditner 2 years ago • updated by Gustav Widén (System support) 2 years ago • 1
What happens to a PWM out signal when it is above the max of 100%. I have a function that is working particularly well at 103%. note: PWM freq = 100Hz.
Satisfaction mark by John Ditner 2 years ago
There was a situation where PWM out channel value wasn't clamped, which made it possible to see this impossible value in IQANdesign. Actual MR of course would not be above 100.
61232PWM out not clamped when using channel as Max MR
Fixed. Now property limits are applied also when the PWM/COUT channel is not adjustable.
