COUT Open Load message disable
Marco 2 years ago • updated by Michael Carlyle 2 years ago • 1
In our application a bidirectional COUT output is used. In some machine configurations the second valve is not connected but this results in the Open Load message being sent on the display. Is it possible to disable this error message on the display?
You can use a constant in an initialization group to control the "bidirectional" setting for the current output to make it unidirectional (just using the positive side) instead of having to use a resistor to prevent open load errors.  Set it and then you need to restart as it is only calculated once at startup.
