In IQAN design how do I select from a joystick input or potentiometer input to drive a the same current output
tcelectronics 11 years ago • updated by Gustav Widén (System support) 10 years ago • 2
I'm trying to select from two different inputs to drive the one output, using a joystick for travel mode input and a potentiometer for sweep mode input. IAny ideas or any programming examples.
Hello Terry, I believed you may use state machine channel (SMC) for this.
In the examples section of the IQANdesign user manul, there is a step-by-step example called "Using states on a remote controlled crane". This gives some ideas of how to use states to achieve a similar function.
If you installed example files with IQAN Creative Studio, you will have a file containing this and other examples here:
\Documents\IQAN Files\Examples\Examples from user manual.ids4
