Format title for measurement in IQANrun & IQANdesign 7
A DOMS 2 years ago • updated 1 year ago • 6
Hi
You did something well in IQANrun 7.x version for the measurements,
it's to name automatically the measure file with :
- the name of the measure group
- the serialnumber of the machine
- the date and time
the problem is that the date is on this order : DD MM YYYY and when we have several measurement, it's not organised by date :
Image 4630
it would be better to reverse the date using this order : YYYY MM DD, to organize the files by chronological order.
Is it possible to have the same thing when saving a measurement with IQANdesign ?
Does it help if you change the Date Format at User Interface ?
No it doesnt change anything on the name of the measure file
Thank you
Do you think you can invert the date format in the title ?
The date and time that IQANrun amends follows the settings on your PC.
Under Time& langue settings in Windows, you have Language & Region, Regional format, then Change format.
Ok it works,
But I get problems in other Windows software,
Could be an option in IQAN
