Use existant internet connexion to access machine
A DOMS 2 years ago • updated by Thomas Moberg (System support) 2 years ago • 1
My system is installed on an excavator where an Internet connexion is able.
Is it possible to use this internet connexion to access the machine ?
Because we often lose connexion with the Bluetooth.
Hello.
it is possible if you connect internet to the Ethernet connection on the master.
You have an option in the system layout on the master that you can either set to always or have a channel to activate the connection.
Image 4649
