No application Available
Todd F Reddick 1 year ago • updated by Thomas Moberg (System support) 1 year ago • 3
What causes blink code no application available? We shipped a programmed module to a customer. They get a blink code for no application available.  MC41
Adding to that question... What is the difference between "No application available" and "Application not loaded"?
No application available is what you would see in a new unit or if you abort a download in the middle so that the module does not have a viable application.
Application not loaded is what you get when you start the unit with the wrong ID-tag or without ID-tag.
The application is still in the module but it is not running.
If you have a master loaded with the an application it should not just lose it.
Did you confirm that the module sent actually had the application in it and that something did not go wrong with the download?
Sorry, correction to the precious statement.
You get the application not loaded when you start the module with the ID-tag shorted.
If you start with the wrong tag or no tag you get the ID-tag error blink.
In both cases you start the module without loading the application.
