DOUT over curent
Louis DUBARLE 1 month ago • updated 1 month ago • 2
Hi all, recently built a 24V power-supplied machine with 4 HS DOUTs driving solenoids. Swapped with 12V solenoids unintentionally, and now 2 are not responding. Also, one of them is providing 24V output without any command. Did anybody ran into this issue before ? There is not any protection to limit output current ?
You do have a over current threshold of 4200 mA for the DOUT HS outputs on the C4x family.
Are you using any external clamping diode on the solenoids?
Indeed, our solenoid connectors (HIRSCHMANN type connectors) do include a clamping diode.
