CRC Channel
chuck emmons 10 years ago • updated by Gustav Widén (System support) 10 years ago • 1
In 4.06 I do not see a value in the CRC channel when using Measure or Simulate. Do we have to look on the CAN bus?
Satisfaction mark by chuck emmons 10 years ago
Yes, to see the counter and checksum values, you will have to look at the bus with e.g. IQANanalyze.
For incoming CAN frames, the GFIN/JPIN and all connected parameters will be set to error status if the checksum is incorrect.
IQANsimulate will only simulate correct values.
