Machine ID
Mark Walser 10 years ago • updated by Ulrik Zakariasson (Software development) 10 years ago • 1
Can you access the machine ID so that you could change it via the display.  We are looking to have our tech on the line add the machine ID (which in numbers only).  This would allow us to add a password protected screen for them to add the ID and other info.  This would allow us to preload the program and tech not have to plug in with a computer on the line.
Machine ID can only be set using IQANrun. IQANrun is also available on iOS and Android tablets, if that is of any help.
